THOMAS'S WEB SITE
Cherry BX-2
Gear Lever Mechanism
The alignment of the running machine was about 1.5mm out of axis to the steel cable. Therefore I had to create a 1.5mm plate to correct that. The steel cable must be perfectly aligned in order to avoid unwanted forces on the installation
Drilling Distance Plate
Checking Alignment with Line
Gear Down Position
Cherry BX-2 Home
4021
Avionics/Instrument
Electrics/Instrument
176
306
Horizontal Stab.
Prebuilding Hours no
Projectinspection
Retractable Gear
97
252
Seating
Stand
Tank
60
Vertical Stabilizer
Wing Loading Test
Workshop
